I found out my video link no longer works cause it was a photocrap link and since we cant edit posts after a time
here it is .. This was my Cadmaro with the 514 8 to 1 BIG cam Black Widow intake motor on a 10.49 pass
A long time ago
71 Fleetwood 5280 lbs plus me 260 lbs stock well tuned 472 300,000 miles
Open exhaust manifolds
15.8 1/4 mile after the Quadrapig disappeared..cant remember mph
14.7 on nitrous burning rubber for a 1000'
77 Eldorado 425
9.1 to 1
16.2. 1/4 mile
71Skylark
76 - 504 pocket ported 902 heads
12.0 to 1
232 @ .050 .528 lift
Geometry corrected Mouse trap rocker arms
turbo 400 stock Caddy converter
4.10
29.5 x 9.5 slicks
13.0 1/4 mile @ 103 mph
512 - same as above with 250@ .050 hyd cam .586 lift
1.75 Harland Sharpe shaft rockers
12.3 to 1
homefit monte headers [ made before adapter flanges were available ]
12.40 1/4 mile @ 110 mph
81 CDV
472 stock bore 9.3 to 1
ported 425 single plane intake
850 Holley dp
236@ .050 hyd cam .568 lift
1.72 shaft rockers
3.23 gear
Very traction limited 13.60
69 Z-28...2960 lbs 3200 with me
514 approx. 8.5 to 1
288 @ .050 .682 lift - .03 lash 102 in 116 ex
1.75 Harland and Sharpe shaft roller rockers
2 Holley 750 d.p
317 cfm @.600 lift heads 240 cfm exhaust. 2.19 in 1.88 ex
3.90 - 57 olds rear end with spool
Ladder Bar car
32.5 x 14.5w slicks
11" 2200 rpm converter
Homebuilt 1 3/4 tube 3" collector headers
10% underdriven 6-71
Boost gauge only showed vacuum
11.19 1/4 mile @119 mph
Changed to 10" Ultimate Street Fighter t.q 38-4200 stall [ more like 46-4800 with the big high comp motor ]
Discovered the belt was bending the pulley down and skipping over it ....Set blower snout pulley spacing 3" back
Still showed no boost
10.49. 1/4 mile @ 127 Going sideways
same 10% OVERDRIVEN
4 lbs boost
10.09 1/4 mile @ 131 mph
After finding out my blower was really a aluminum shaving injector
No BLOWER same motor and converter
Added Black Widow intake and 1150 Dominator
2880 lbs plus me
31.5x14 slicks
10.49 1/4 mile @ 128 mph
524. 14 to 1
274@ .05 .430 lobe lift solid roller. .752 lift -.028 lash with 1.75 rockers ..108 ls installed 3° retarded
330 cfm heads @.600 lift 2.25 in 1.9 ex same exhaust flow numbers
9.65 1/4 mile @ 136.96 mph
Never did get rid of the Wheel hop that caused mid track spinin
The Mad Banana
79 CDV
425
2115 intake
950 Ultra XP
MT10 cam installed straight up
Cadco headers
3.23 Caddy rear end with Eaton Posi
275x60x15 Coopers
Made several passes but had a sheetload of trouble with stupid things like trans not shifting
etc.. Still ran 14.7 @98 mph..
didn't shift until 5700 and went from 1st to 3rd gear
with obvious major traction issues and tossed the belts
from the 1/4 mile mph it should have easily ran mid 13's
Hopefull update with the Mad Banana Boogieman motor soon
