restorencads
Hello all,
Well I'm starting a new fuel supply project. All help would be greatly appreciated. I've decided to attempt a tbi install on a 472 cad motor. I've gone out to my favorite pick a part and gotten a tbi system from a 1995 Chevy 2500 pickup with a tbi 350. I've got the ECM-16197427, throttle body, and complete engine bay wiring harness with sensors. I will be purchasing a 1981 FI 368 distributor for the project. Any suggestions for fuel pump for this application (part# preferred)?
I will be taking this project step by step. I want to get all parts ready for install and then finally install. I will be worrying more about programming later. My questions for now are. I'm looking at the huge pile of wires and thinking "I like wiring electronics, but what have I got myself into?" I obviously won't be needing the part of the harness for the transmission and other lighting. Could I use the manual to decipher what wires go where and remove unnecessary ones like transmission? Basicly as I understand it, I will only need the wires going to the ECM that power it, ground it, go to sensors, throttle body, ignition, distributor, and fuel pump. Can't everything else go? What about the knock sensor for the cad motor; I understand the knock sensor is engine specific, but won't it make the spark control go crazy? What is the remedy. Next, to for warn you this is a later model '95 so it has the ESC inside the ECM. What wire connections are required for connecting the 368 distributor? I really didn't want to get involved with egr, it isn't on the engine now, and seemed like a lot more trouble. But, what do you guys think? If it were installed would I need the air pump reinstalled, flapper exhaust manifold, and egr manifold.
Well I suppose that is enough for now. Sure to have more questions in the future. Thanks in advance for any and all help!
Nathan
Nathan
