The Mad Cadder
PROSTOCKTOM said:Because of the rotation of the crank you want the suction port on the drivers side.
The oil is already heading that way, so that's the best place for it and why dry sump pumps are usually mounted on the drivers side.
Tom
That might be correct if he only has a hole in the side of his pan
On wet sump that would be a horrible idea !!
From memory it is a tube that goes to into a pickup box in the middle
of the sump .
It does look to be a bit far foward :twocents:
