Maddog
Terry---as I read the above StanJ is donating a 1475 for you to cut up and Matt83 agrees with you completely. LOL.
Maddog
Maddog
Maddog said:Terry---as I read the above StanJ is donating a 1475 for you to cut up and Matt83 agrees with you completely. LOL.
Maddog
StanJ said:the only way either will become a reality is if someone takes a "dammit, I want one, I've got the $$$, and I'm gonna make it happen" attitude.
Nick Campagna said:Very true Matt. An application which could use a better manifold is the 69 - 78 Eldorado. Their hood line is too low for even an Eldelbrock, and the modded stock can be marginal with a really strong motor. The uphill design of the runners is a problem.
JW said:Just an RPM airgap would do it IF it worked enough better than the current intake does.
Thing is you could not really make a DP to work for everything ,reason being if you size the manifold internally to fit an iron head and the mts head with a little adjustability in making the outlets of the runners larger for a ported head ,anything beyond that would weeze kinda like it does now.
Make the manifold large enough to cover the range of heads available now and it would be the last thing you would want on a mild engine.
Kinda like the difference between a cobrajet intake and a generic 429/460....one application will not work for both.
The low hoodline car owners just need to convert to efi and even a MTS intake could be used.
Wack about 3/4 of an inch off the intake and a low profile throttlebody and you are there.
mt83 said:Maybe a production cowl hood would be a better compromise to make this possible? I would love to see an old caddy cruising down the road\strip with about a 4 inch cowl. I think it would be sexy :bitelip:.
mt83 said:The few engines I have built and returned to original Cadillacs, while equiped with a 2115, haven't had any hood problems. We used a drop down air filter and everything fit. There was atleast an 1.5" between the breather and the hood.
mt83 said:Nice!!!!! Is that a production piece and if so by whom?
So Miles............did you run it on the dyno??? Any idea if all that work paid dividends?? :reading:MOCRUZN said:JW said:I believe Miles had a edelbrock on his engine and have never seen a dyno sheet on it
Yes I do, JW, technically. It still has the factory casting number but that is the limit of the original design elements remaining.
StanJ has performed various mods to fit CPP heads; a full height divider (no gap), 3" spacer, 4150 base carb. The 4150 discharge flow pattern is cnc'd through the spacer all the way to the floor of the plenum, the runner entry into the two planes is hand blended from the plenum.
It remains a dual plane but it isn't a 2115 now.
Miles
dave brode said:Matt,
Apples to oranges, perhaps, but look at the stealth on the 460 test. Pretty darned good showing for a torque vs horse trade off.
