Thanks guys.
grendel, yes, '71 with '67 front end. The turbo setup was a learning experience. Much of it was done through guesswork while there was no front sheetmetal on. Ended up with too little room, and could only get 2.5" downpipes from the turbos. this [I believe] choked it off early.
Edit: I've been at 67-72 trucks, but not for a while.
Sean,
I don't know what'll be next. Some fun for a bit, even if it's slow fun lol. I might put a high compression engine together for a track rental event later this year. I have a solid can, rollers and most other stuff needed to do that. I'd like to re-turbo the truck, but it'll be next winter for sure. I would like to move the opel inside and work on it a bit too.
Terry,
It's been a while since I've played with a Q-J. Kinda fun. I will say that opening up the idle tubes and idle down orifices does seem to really make the carb snappy. It still needs a little more idle bypass air though. Going from .070" to .082" allowed backing the throttle plates down a bit more, but it's still 1/2 to 3/4" turn open from where it needs to be. I'll try a bit larger bypass holes, hopefully, I will not have to drill the throttle plates for add'l air.
