well, went to install that crane ign box, got everything hooked up (correctly?). and it appears that box isn't getting a signal from the pickup, inside the distributor. both pickup wires are the same color. there are 2 different size spade female connectors, one a 1/4" and the other a 3/16". I've tried it connected each way.... but nothing. I hope the box isn't bad. or
I'm wondering if anyone knows for certain which is Mag+ and which is supposed to be Mag-.???
if it's the pickup then can that be replaced w/o pulling the distributor? if it's not possible then how much of a pain is it to re-install?, with either scenario if the oil pump drive stays in the oil pump or if it comes up with the distributor? or does the strong likelyhood that neither will happen and it goes into the oil pan?
seems like everything goes wrong all at once. :irked: :banghead: :cursing:
