Don
Howdy All,
Been working on getting Cooke's Headers into the Regal, and were close. By close I mean Damn Close. Had to use a saw's all to cut the frame and trim part of the a-arm,heat, beat and bang some and raise/lower the engine too many times to count. Before I bolt them up and start this new build up I'm thinking how Damn Close those tubes are to the starter, brake lines, and the plastic fender wells. I do not want to remove the inner fender wells if possible and I know it would be a good idea to insulate the starter from the heat. Have any of you used header wrap with any success? I was going to give them a fresh coat of header paint, but that may only make them look better and not reduce the heat too much. Looking for advice on what to do and whats been done. I also have a real tight fit getting the hood to close with an air cleanerhaving to be Very Low Profile it anyone has a suggestion there as well. I have started to look for a Cowl Hood, but do not want too tall of a Cowl. I found a 21/2" hood last night and I love the Grand National Hoods, but don't know if I would gain any clearance there. With the Headers under the stock hood I can almost feel the heat generater by the headers and I know the Caddy would love to get some cooler air.
Thanks In Advance for any Help
Don
Don
