The guy I bought the motor from told me it was a 500 and had several of these motors and transmissions and was pretty knowledgable about them so I'm quite sure its is a 500 but I will take some pictures of the motor and stick them on here.you should make sure it is a 500 and not a 472
I'm located in Southern IL.Where are you located Abe?
Yes the steering box is in front of the crossmember.Is it a front steer ? Is the steering box in front or behind the front cross member
I don't recall how the A frames sit, but will have a look.Do the A frames ,where they attach to the main frame rails, rise up as you look from back to front ? Or are they parallel to the main frame
Lots of good information there. I will probably go back to read over again when I come to fitting the motor in. None of the pictures would come up though. Said they didn't exist anymore.Search "Time to Fess up" ,a lot of the build on my car is explained there .
I will probably put headers on the motor.Are you running headers or a stock exhaust manifold ?
