Road Kill Gremlin/500
robocop
Miami, Florida
Freiburger has revived the 500 Cad powered Gremlin. They put in a new engine which failed. They repaired it but ran out of time before we saw what it was capable of doing.
I will say it was inspiring to hear a Cadillac running at full throttle, even for a moment.
Ditto on seeing and hearing the Big Caddy run!
But what does that guy have against doing a job right? Damn!
I think you have to have drama to get better ratings!:whistle: and it allows another show down the road.
That’s an old episode, the new engine came straight from CadCo. Just got screwed with a faulty lifter, not really anything they did personally.
Apparently every TV host has something against doing a Caddy build up right.
Richard Holdner got that old Gremlin engine from Freiburger , which then CadCo rebuilt and Richard dyno'd it. Then Richard turbo'd it and screwed it up and blew the head gasket catastrophically on the dyno. Then he left coolant in the cylinders and stored it, so it needs rebuilt again.
Then those guys on Power Nation were building a cad motor for nitrous and putting it in a hearse, then never aired the episode of what happened. I assume they blew that motor.
I'd say that the number one reason for blowing these engines up is skimping on the valve springs............................which leads to lots of other bad stuff. That is very likely the limiting factor on lots of different engine brands. The most adequate valve springs on earth for a street/strip engine don't cost more than a couple of hundred dollars. They just aren't a glorious engine part and people just aren't going to spend coin on them..
The turbo deal was messed up, too small of a housing, plus an iffy distributor was bound to go down that way.
not to sure about the power nation folks, but tuned out after I heard them using 425 heads on that combo.
This time around that wasn’t the case, the entire engine build was done by CadCo. Once they discovered the messed up pushrods and lifters they even pulled the springs and checked the pressure at installed and .500 lift.
Not saying the guys are without fault, but they appeared to be trying to do the right things given the time constraints
sadly I haven’t seen the caddy gremi reappear yet and it’s been a couple of seasons.
JW broke the news yesterday ran 9's in the 8th, 6400 lb hearse with 150 shot. Figure about high 14's - low 15's in the 1/4 he said. Motor survived, excellent bottom end! ( sorry for the spoiler):lipsaresealed:
Doug in P.R. :cool:
That thing made 258 hp and 323 lb-ft of torque??? What the actual hell??
Sad attempt. Sounds like crap. Runs worse. And it’s claimed to be the world record holder.
Are you gonna take it down?
Horse power and torque readings at the rear? Sounds like POOP! DOUBLE :crap: :crap: ! Sorry, :crap::crap::crap::crap::crap:!
My naturally aspirated, 20+mpg, daily driven, high mileage, 370 cubic inch, handles like it's on rails, 7.86@87mph, 4500lb hearse wannabe put down 461hp/428tq at the rear wheels.
