tommyhawk13
I'm about to give up on this. I've been trying to figure out why my Cad is stumbling for way too long now. I've got black sooty plugs, and the choke butterfly looks the same.
The car (74 com ch)) idles a little bumpy, and the motor vibrates like a dryer with a pair of shoes in it. :banghead:
Off idle, the motor hesitates and you can hear that it is not firing for at least a full second. It does this all the way up to highway speed, at steady throttle or speeding up. If I mash the go pedal, it gets worse. At a steady speed of 65mph or more, it seems to settle down.
I've gone through everything in the ignition, so I last night I went back to the carb again. The fuel pump is stock.
The air cleaner is fresh.
I tied off the secondaries with some wire, so they would not open. That did not help.
I checked all of the vacuum lines. Ok there.
I turned in the idle mixture screws all the way in, and the car still ran! :censored:
I let it idle for a good bit, hoping it would just burn up the gas in the bowl, but it just kept on running. It did sound a little smoother. :screwy:
I figured the float must be set too high, or the needle wasn't seating properly, so I took the air horn off (carefully). I rebuilt this carb, so I was beginning to doubt my handiwork. I checked the float level, it was at 9/32", and the commercial chassis level s/b at 19/64". I'm ok with that, right?
I checked the hook on the needle, to make sure it was in the right place.
I pulled the needle out & everything looked ok.
I put it all back together & the problems are still there. I gave up at 1:00 am. :tired:
The carb should run out of fuel with the idle mixture screws all the way in, right?
Right? :listen:
Right? :listen:
