A
Anonymous
Hey guys...
The people on the Mopar boards seem to dislike helping me because I'm asking a question about a Ram truck and not a cuda or charger, so screw them, I'll ask it here:
What happens when one of those ECU ignition boxes starts failing? Thats the one that every Chrysler product from '73 on till EFI or later had.
The one on this truck has gotten hot enough to liqiefy the epoxy in it until it ran down the firewall and onto the ground at some point in the past.
Only after I drove it home did I discover that there was some electrical event resulting in a charred negative cable, charred alt wire and a new voltage regulator..just like if the battery was hooked up backwards :shakehead:
I picked up a carbed '84 Ram with a 318 and that dumb thing started acting up out of the blue. Crank it up and it runs fine when the engine is cool, but once it warms up, if you gas on it, it'll break up and backfire out the tailpipes BAD, then finally die unless I let it fall back to idle.
I have some testing ahead of me on this but I'd like to get an idea about it first, thanks.
