I'm considering replacing my '73 Riviera with a '70 DeVille. The car has ~100k, one owner, most/all service records, the original window sticker, etc., and it looks like it's always been garaged and appears to be in good shape. Is there anything in particular that breaks on these cars that I should be looking out for? I'm having the seller do compression and leakdown tests on it and a cooling system pressure test; I'm aware of the timing chain issue but that's not something that I can check before I buy it, practically speaking. I'll be driving it ~400 miles home, so I'll just have to hope that it holds together and have it replaced as soon as I can afford it after I get it here. But I can't think of anything else to do with it before I buy it from a mechanical inspection standpoint, short of driving it and making sure it runs properly.
It appears to be rust free but I'm figuring that since it's an early 70s GM product I should probably check around the back window and in the trunk particularly carefully.
Outside of that, and making sure that all of the accessories and power options work is there anything in particular that goes wrong with these cars that I can check before I buy it?
Any insight would be appreciated.
Thanks,
Kevin
Thanks,
Kevin
