What head do I have, who's shaft rocker assembly, and how to id cam?
Lil'John
Georgetown, CA
71, 72 Toyota FJ55s
I got brave and knocked the cam freeze plug off the back.
I found two lines on it:
268H-10
YAG-160
The first line almost looks like an MTS number... the 268 lines up with the MT10 intake duration. The second line doesn't look familiar... the G could be a 6.
Am I guessing right?
Should I replace the cam freeze plug with a steel one? Or brass?
Steel on the cam plug, even though I'm not sure it matters. I've never seen or used a brass one since there is oil behind it and not coolant.
My guess on the numbers, and it is a guess, is 268 duration, with a 110 LSA
Looks like a Comp cam number. 212 degrees at .050. Like an MTS #5 cam. Good smooth low speed ca woith a little extra low end torque.
I’d say that you just found out that your cam is just about perfect for your application.
