Valve springs for this CSOB
Discussion in 'Big Block Cadillacs' started by MIHELA, Sep 8, 2018.
  1. MIHELA
    MIHELA Active Member
    Apr 29, 2016
    152
    46
    So I just got my engine back together after discovering 2 broken valve lifters. I have an MTS 5 cam and am still using the original springs and plan to upgrade springs and shaft rockers. Any recommendation for basic springs that will support a max of 4500 RPM without float, and low enough spring pressure to not worry about cam failure? I am under the impression that SBC springs work with minus locks, but the threads here can get a bit muddy on specifics. I'm just looking for something that can go together and not have to worry about broken pedestals if I go on a long trip.
  2. Darius
    3,792
    373
    Okay, HOW cheap are you???
    SHAKEDOG likes this.
  3. MIHELA
    Apr 29, 2016
    152
    46
    Are they the correct diameter? Or do I need bigger valve covers?
    El Diablo and Darius like this.
  4. Darius
    3,792
    373
    LOL! Great reply! Thanks for the laugh.
    If memory serves there is a ton on valve spring information under the search tab. Some of it put there by other's who like to save money.
  5. El Diablo
    El Diablo Active Member
    Apr 25, 2013
    360
    79
    Yuma, AZ
    1959 Cadillac Sedan deVille
    I don't recall the part number for the springs that I am using now, but they are a Comp Cams SBC spring if this is any help.
  6. PJ McCoy
    PJ McCoy Active Member
    929
    185
    Screenshot (14).png Screenshot (15).png I used the Beehive spring but had to machine the heads.
    this should help. It gives the inside diameter and outer as well. With a shaft system you will be good to go. Are you going bigger on lift?
  7. Ted in Olympia
    Ted in Olympia Well-Known Member
    5,264
    39
  8. Ted in Olympia
    5,264
    39
  9. MIHELA
    Apr 29, 2016
    152
    46
    I wonder if those will clear with the damper springs. They look about like what I need though.
  10. MIHELA
    Apr 29, 2016
    152
    46
    On closer look they are .870 ID, I think that's too small IIRC.
  11. Ted in Olympia
    5,264
    39
    I would remove the dampener springs
