Switch pitch pumps, converters, solenoids etc.
Discussion in 'For Sale/Wanted' started by hertzdaddy, Aug 9, 2016.
  1. hertzdaddy
    hertzdaddy Active Member
    Jul 30, 2007
    1,019
    Richmond, VA
    I have a bunch of switch pitch parts for sale. Here goes.
    SP pump, input shaft and forward drum. Pulled from a 67 olds TH400 with unknown miles. $200 plus shipping obo. 13" converter from same trans. $50 plus shipping. Heavy stuff!
    [​IMG]
    SP pump of unknown origin. Solenoid is there but wire is broken with small lead left. $100 plus shipping obo. 12" SP converter shown in pic $100 plus shipping. Converter is from 67 olds ST300 trans.
    [​IMG]
    12" SP converter from 64 Olds St300 trans. $100 plus shipping.
    [​IMG]
    NOS SP solenoid. $20 plus shipping.
    [​IMG]
    SP intake-mounted activation mechanism and harness. Came from either a 64 or 67 Olds. Cool original part. Tell your Olds buddies. $50 plus shipping obo.
    [​IMG]
  2. hertzdaddy
    Jul 30, 2007
    1,019
    Richmond, VA
    Bump.
    All parts obo.
  3. hertzdaddy
    Jul 30, 2007
    1,019
    Richmond, VA
    Still have the switch pitch conversion parts for any TH400. Includes pump, input shaft w/drum, solenoid and 13" converter.
    [​IMG]
    Also have a spare NOS solenoid.
    [​IMG]
    And a spare pump (converter not included.
    [​IMG]
    I'm moving so make an offer. Otherwise its getting recycled.
  4. hertzdaddy
    Jul 30, 2007
    1,019
    Richmond, VA
    Hey Fleetwood, check your inbox.
  5. hertzdaddy
    Jul 30, 2007
    1,019
    Richmond, VA
    Bump. Fleetwood gets first crack if he still wants it. I'm in Seattle now, sooo there's that shipping thing. Heavy stuff!
    Email me since PM seems hit or miss.
  6. Darius
    3,711
    347
    Even after all these years of hearing about switch pitch transmissions I had never seen the parts laid out.
    Thanks for the pictures.
  7. PJ McCoy
    PJ McCoy Active Member
    921
    185
    Curious about two things.
    1. Does the pump need the drum and input shaft to work?
    2. What is the stall difference from stock. Meaning when you switch the pitch.
    Thanks
  8. hertzdaddy
    Jul 30, 2007
    1,019
    Richmond, VA
    It needs the shaft, but the drum is standard TH400.
    Stall difference depends on which converter (12" or 13") and engine torque. Can't remember the stock specs but its posted elsewhere on the site. Somewhere around 1000 rpm diff. for the 13" and maybe 1500 for the 12" in stock applications? The 13" starts lower than the 12" too. They can be modified for different stall speeds as well.
  9. dave brode
    dave brode Well-Known Member
    14,856
    135
    Some claim different, but several 12" V-P convertors that I've had, or been involved with went 2000 in low, 3000 in high. Anything from 3000 lbs to 3600 lb cars. I believe that when the "rebuilders" re-do them, they somehow screw them up. A friend had a rebuilt 12" [recon] that would only go 2400 in high. He put a junkyard 12" in, bingo = 3000 stall.
    Two 13" that i've had were 1000 in low, 2500 in high.
    As HD wrote, you need the input shaft, easiest to just use the shaft and drum from the donor trans. You need the pump, solenoid on pump, two prong wire terminal for case [still sold, was used later for "smog" wiring].
    ***** you need the resricting orifice cup from the case of the donor trans. It's in a passage behind the pump flange at apx 8 O'clock, looking at the case. You can fashion one from a glass fuse. Can't remember orifice size at the moment......
    ***** You need [easiest, anyway] an 8 BOLT CASE. The 6 bolt cases do not have the plumbing req'd. Afaik, Bruce [member here] may know how to make them work in a 6 bolt case.
    Someone should get this stuff. Shame for it to go to scrap.
    Btw, I'm not sure that Jim Weise is doing them any more. Tri-Shield might be, but imo, they should be avoided.
    DB
  10. PJ McCoy
    921
    185
    Ok. Thank you both... very good info. Ill find more here on the forum. I think i remember reading something about it. Dave did you use some quotes from the forum you posted above? I remember reading something about the fuse ends i thing someone was trying to convert on but something didnt match or couldnt work. Maybe a eldo front wheel drive. Idk.
    Thank for the info. Ill find more on here.
  11. cadbrad
    cadbrad New Member
    Nov 4, 2017
    2
    0
    ripon wi
    500 cadillac x gm pickup
    Are these parts still available? I am interested in the sp pump, input shaft, and the 12" ST300 converter.
  12. cadbrad
    cadbrad New Member
    Nov 4, 2017
    2
    0
    ripon wi
    DB[/QUOTE]
    If Jim doesn't do them anymore and Tri-Shield isn't a good choice, is there a recommended shop that can rebuild a VP converter for "like new" or better durability?
  13. hertzdaddy
    Jul 30, 2007
    1,019
    Richmond, VA
    Everything is sold now.
    8ad-f85 and PJ McCoy like this.
