Finally got the motor put together and fired it up on the test stand, broke the cam in at 2000 RPMs without issue. Currently struggling to get this thing to idle correctly though due to very low vacuum below 1400-1500 RPMs. I did not have a cam card for this engine as I bought it from a gentleman who had put it together a decade prior and lost it (only thing he wrote down was .500 lift, .270 duration). Used Stage 1 valve springs which Cad Company recommended. I installed the cam dot to dot (camshaft at 6, crank at 12), new cloyes timing set. Rebuilt a qjet with kit and advice from Cliff Ruggles but still have the stock qjet that came with motor. The distributor had a recurve kit put in, red springs installed from what I can see. Cannot get vacuum above 5-8 inches at anything under 900 RPMs. Vacuum at 1200-1400 RPMs is 18-25. Very responsive to throttle and anything above 1300 RPMs. Nozzle drip noted on the qjet so dissembled the rebuilt qjet, test fuel inlet seat seal with vacuum, reindexed the throttle blades so they're as close to fully closed as possible, rechecked float level, still having nozzle drip but not suprising with the low vacuum. I also installed the old cadillac qjet and same thing, nozzle drip and very low vacuum at lower RPMs and unable to get close to a idle. So I removed the aluminum intake, it appeared like the previous gasket may have had a leak. Reinstalled a new gasket with high tac and RTV around all ports and pretty much along the entire gasket surface. Still the same situation. I installed the distributor at -10 BTDC for #1 and ran like trash until I advanced it considerably and would run great above 1300 RPMs. I have run out of options for things to check besides possibly installing the cam 4+ and see how it reacts? Or possibly could have something wrong with this distributor? Any advice would be greatly appreciated. Did check compression on all cylinders, all at 150#-180#. When I had the intake off and valve covers off I did not notice any damage or anything out of place.
