Discussion in 'Big Block Cadillacs' started by Darius, Jan 2, 2014.
  1. Darius
    4,231
    709
    Here we are, May 12th, Mother's Day in the year 2019 and the weather is FINALLY such that it invites us to be outside, or in our garages, and working on Big Block Cadillac engines!!
    Life it Good!
    Also, this being Mother's Day my son and I decided to bake a German Chocolate cake - from scratch - for "Mom!" Being gentlemen DSCN3640.JPG DSCN3641.JPG DSCN3642.JPG DSCN3644.JPG we did help in the sampling.
    Best to you All,
  2. Darius
    4,231
    709
    Howdy Gentlemen,
    Wondering, (before using the search function - which I will do AFTER this) what experience folks here have had with the Sanden air conditioning compressors? It seems there are many knock-off of the Sanden as well. Anybody have experience with those?
    I memory serves I believe it is the Model 508 that best fits our big Caddy engines when they are equipped with the Edelbrock intake manifold. So what is the experience??
  3. Mike P
    Mike P Member
    Feb 10, 2009
    175
    19
    I'm running Sanden 508s on 5 of my cars including the Caddy powered El Camino (with stock intake). Some have been on over 10 years and in the case of the El Camino over 80,000 miles. Never had one fail or need replaced. One of the five is a Chinese knock off ( I didn't read the E Bay ad close enough). It's always been a little noisy but works OK.
  4. Darius
    4,231
    709
    Mike, thank you.
    I did use the search function and see that most suggest the Sanden TYPE or the factory original, which is the way I'll go. Looking for success, not do-overs.
  5. MIHELA
    MIHELA Active Member
    Apr 29, 2016
    199
    74
    I have been eyeballing the Sanden 4860 myself. It's in their FLX7 line. They have removable rear fittings in a variety of styles.
  6. Darius
    4,231
    709
    QUESTIONS:
    Is the Sanden 4860 the same size externally as the 508? Will it fit in the same space (using the Edelbrock intake) and does it have equal cooling capacity? Displacement for the 508 is 8.3 (cubic inches?) but displacement for the 4860 is 155 (somethings).
    The specs are:
    Compressor Family: SD7H15
    Style: HD
    Mount Type: Ear 8 Long
    Ear ID: 83.3
    Refrigerant: R134A
    Displacement: 155.00
    Rotation Direction: CW
    Oil Qty (cc): 200
    Cylinder Head: GV
    Port Angle: H
    Port Clocking: Rear
    Head Port Style: O-Ring
    Rotor Size: 125
    Rotor Groove: A2
    Coil Voltage: 12
    Connector: 1 Wire Male Packard #12015791 W/ Diode
  7. kboots16
    kboots16 Member
    Feb 19, 2012
    32
    6
    White Lake, Ontario
    I know very little about air conditioning compressors. Numbers, I'm a little more familiar with. Since I live in Canada, and we are in between the metric system and the Imperial system, I would guess that the 155 is cubic centimeters (cc's for short). This converts to 9.46 cubic inches.
    Check it out. Maybe this will give you a starting point.
    Ken.
  8. MIHELA
    Apr 29, 2016
    199
    74
  9. MIHELA
    Apr 29, 2016
    199
    74
    I guess the 4616 is a SD7h15 "enhanced" compressor. 15-20% improvement in capacity in the same package size. Big difference in price. These would both be the modern descendants of the 508.
  10. Darius
    4,231
    709
    kboots16, MIHELA,
    Thanks to both of you.
    The "guess" that the 155 represents metric quantities is plausible which means that you probably right. I'll find out when I make a phone call to Sanden customer service technical.
    Good to know that the 508 series is "old news" and probably replaced by one of the other two mentioned. After having looked at them I don't see much difference either, other than one taking more oil than the other (if my memory is correct). Again, tomorrow's phone call will probably make sense of it all. At least that's the hope.
  11. 5one9
    277
    85
    Good info on the 4616. That’s what I’ll try to adapt to my application
  12. Darius
    4,231
    709
    Well, life happened over that past two days and I never made the phone call to Sanden Customer Service to learn about the new replacements for the 508 series of A/C compressors. That will have to wait until next week.
    But, my TIG welding has improved!! Hell, it couldn't do anything but improve!! Pictures tomorrow - maybe.
    5one9 likes this.
  13. Darius
    4,231
    709
    Following up on A/C compressors for our engines:
    The other day I thought I had found a phone number for Sanden but after searching today I gave up on making a phone call and wrote them instead. Here is the text of that note.
    "I'm a car hobbyist. Several associated and I favor the old, big Cadillac 500 cubic inch displacement engines. In the past when upgrading to newer intake manifolds our original Harrison A6 A/C compressors would not fit so many switched to your Sanden 508 units.
    Are the 508s still made, and if not, what part numbers would be a suitable replacement in physical size - and cooling capacity?
    Word is that your 4860 and FLX 7 lines might be possibilities.
    Thank you,
    Darius Gray
    5one9 likes this.
  14. 5one9
    277
    85
    I’ll be curious to see what they tell you
  15. Darius
    4,231
    709
    OKAY, REMEMBER THE RULE: No laughing allowed!
    Regarding TIG Welding - 101, Month #1
  16. mario
    mario Well-Known Member
    2,941
    131
    Bro d:
    Kinda reminds me of the Rosetta stone ...:whistle::whistle::whistle: you'll notice, I'm not laughing.
    Ciao,
  17. Darius
    4,231
    709
    I appreciate the restraint. ;)
  18. 5one9
    277
    85
    Everything that you thought you knew about TIG changes with stainless. I’m trying to get there myself.
  19. Monzallac 425
    Monzallac 425 Active Member
    Jul 16, 2008
    858
    52
    Salinas, Puerto Rico
    I see rainbows on the top one, looks good to me......:thumbup:
    Doug in P.R.:cool:
  20. PJ McCoy
    PJ McCoy Well-Known Member
    1,159
    339
    hey D can you number them from 1st to last? looks better than anything Ive ever done. keep at it
