Rebuilding a 425
You talk about being bored? While I am waiting for my 1970"binocular piston " 472 block to come back from the machine shop (being zero decked and cylinders honed) I started clearing out my garage and the low mileage 425 I pulled out of my '79 to replace with a large chamber 9:1 472 "jumped out" at me. Soooo, I am rebuilding it for something to do. Cylinders have been honed (stock bore with VERY little taper, new cam bearings installed and Moly rings ordered. I will post the progress, again this is to keep me from going stir crazy, so any conversation on this is welcomed.
kzhurley
I am rebuilding a kohler 12hp engine that doesn't need rebuilt for a mower that I will never use.. Lol
No worky for me for a few weeks "officially". I'm sure it will turn into months
kzhurley
Ive always wondered how well a 425 would do with some early small chamber heads and some cam. I know I'll never get to it since I have a couple 500s to go through first
I've got several 500's and 472's that are waiting their turn but this is a project that's just to be doing a project. I have absolutely no idea what I am going to do with the motor when its done.
Cooling system differences (between 5200 block and 425) prohibit just swapping heads. Besides with the flat top[ 425 pistons and 76 cc's in the chamber you have something over 12:1.
Is the Kohler motor for a riding mower?
kzhurley
Yes. For a cub 72. Originally 7hp lol. Wanted a 16hp but couldn't find a good core for a reasonable price.
Then there is no problem. Ditch the Kohler. Cad 425 more fun.
. Show this guy who's boss:devil::devil:
This "engine sickness" is more pronounced than I imagined!!!
Heaven help us!
bro. "a life time sickie," d
kzhurley
Aside from the cooling differences, which may or may not be major issue, just a rough estimate with a comp calc going from 96cc heads with 8.2:1 comp to 76cc would be more like a little under 10:1.... Very rough measurement.
IF it did work out with cooling ports and whatnot, I think the larger ports of the "big" big cad heads and some kind of 230ish cam would make it for a decent revving and still have lots of torque to play with.
Again, all hypothetical as I'll never bother to do it, lol. Especially with all the 500s I,need to use up first.
I don’t think that ‘small’ bore would handle much of a valve size increase. I agree I don’t think the compression would be that high.
robocop
Miami, Florida
A 72 cc cylinder head on a 428 Pontiac gives a nominal 10.75:1 compression ratio. But they weren't actually that high. More like 10:1.
The Caddy early combustion chamber is a lot like modern LS motors. With a tight quench and a wide LSA cam it might work on pump 93.
Just rehash the motor and dump it in the old John Deere. And have fun cuttin the grass!
Moly rings, crank turned and main and rod bearings, cylinders honed, new cam bearings, probably an MTS #5 cam with Cloyes timing set, reworked oil pump, Flow kooler water pump, perhaps some head work and probably some more when I get to it. We have at least the month of April.
Greg Surfaas
Well, Sunday seemed special so I did a bit more on the 425. The block is prepped. I have the crank that I was going to use in rebuilding the 425 before I decided to go to the 472. It was machined by MTS and the mains were turned 0.010 under, mikeing out at 2.490”. Installed the rear seal and laid the crank on the new bearings using GM Engine Assembly lube. Torqued the mains to 90ft/lb. with a piece of 0.001-.003” plastigage between the bearing and the crank. Results show a clearance of 0.001”.
Enough for one day.
LOOKIN GOOD!!!
Funny how much gets done when we're bored.
bro. "keeping himself busy," d
