Oil pump
robocop
Miami, Florida
I think I have a bad rod bearing in my 500. At low rpm there is no noise but there is a loud rapping at higher rpms. I did hammer it a lot and I have a stock 35lb pump. It has the MT10 cam and would pull hard to 4800 rpm. I did that a lot. So I'll be pulling the engine and might as well get a high psi pump. Which one fits in the G body chassis so I don't have to use the remote filter set up? I've found it only costs me maybe 2 psi but I want to get rid of it anyway. Application is a 87 Cutlass.
I drill and tap the pipe plug from the oil pump 3/8-24. Then taper the hex side of plug for oring. Take a 3/8-24 nylons nut and thread it on the bolt backwards. Machine lip on bolt for spring location. Install oring on bolt after nut is threaded on. Then thread into pipe plug. Install in oil pump. Set oil pressure by threading in bolt. Tiighten nut to secure. Oring seals in taper of pipe plug.
My method of Oil Control.
