Oil control
Very good. Innovate. Looks like you had made a flange yourself.Take a pump gear on a pump drive shaft and look at thar sharp turn the oil flow has to a make to get into that gear. I contour that area. The gears pull oil along the body of the pump. Looking at the oil pump interface on block the gear closest to the pan rali spins counter clockwise.
Picture of oil inlet blended into pump cavity
