Need crank hub
Discussion in 'For Sale/Wanted' started by South65ss, Oct 25, 2018.
  1. South65ss
    South65ss Member
    Aug 17, 2009
    36
    3
    Uruguay
    Hi there!
    Need a crank pulley hub for a '69 472.
    Anyone?
  2. South65ss
    South65ss Member
    Aug 17, 2009
    36
    3
    Uruguay
    Nobody?
    Need hub and harmonic balancer.
    Any clue where can I get them?
  3. Darius
    4,231
    709
    Not that it helps but I had one and gave it away a couple of months ago. They are out there!!
  4. kzhurley
    kzhurley Active Member
    Jan 10, 2011
    380
    173
    I have a few but I do not know what years/engines they are off of.. There are different clockings of the keyway.
    Mine are most likely later 500s
  5. Cadiac
    Cadiac Active Member
    Nov 27, 2004
    1,861
    Wichita, Kansas
    Also have some but don’t know years either. You could redo your timing marks
  6. South65ss
    South65ss Member
    Aug 17, 2009
    36
    3
    Uruguay
    Ok guys, that's great! Need the hub first. Price?
  7. gary kosier
    gary kosier Active Member
    Feb 26, 2005
    692
    46
    Newark, Ohio
    Cadillac only listed the pulley and hub under a single part number. So there is no way of knowing which hubs match
    and which ones are different except by matching known units. So it's all a big crapshoot.
    Gary Kosier
  8. 48Austin
    Oct 14, 2017
    466
    255
    Why not go with CadCo or MTS? Don't know you're application. But if it is for HP, then this is the way to go.
  9. Cadillac Kid 1
    1,113
    226
    FWIW they do not list the crankshaft hub as being a separate part in the parts book I have. I also just looked at the 6 hubs I have and aside from a difference in the machining of the flange edge (some are beveled and the others are squared off) they all seem to be clocked the same with a bolt hole exactly at the key way. I believe any changes in timing mark locations would be with a combination of pulleys and timing marks themselves.
    I would part with a hub but they are all for engines I have.
  10. 48Austin
    Oct 14, 2017
    466
    255
    They have them listed as one piece SFI units. This is the way I am going to go.
  11. 5one9
    277
    85
    Still need one? or both?
  12. South65ss
    South65ss Member
    Aug 17, 2009
    36
    3
    Uruguay
    No sir. Thanks!
  13. DevilDeVille
    DevilDeVille Active Member
    Oct 4, 2010
    289
    29
    Estonia (next to Russia)
