louvres eldo oil pan
Discussion in 'Big Block Cadillacs' started by Caddy123, Feb 19, 2018.
  1. Caddy123
    Caddy123 Member
    Sep 9, 2016
    49
    Hello everybody I have a eldorado 1970 oil pan.
    In the front of the pan are louvres or how you cal that ( my inglish is a little bad!)
    I have cut them out, the pan was full off dirt and cant clean underneath!
    must i welded new louvres?
    gr Danny
  2. blue68deville
    blue68deville Member
    Dec 7, 2011
    145
    23
    Denver
    I bet you could leave those out. They don't look like any kind of oil control, maybe just reinforcement. That is the front of the sump, right?
  3. 8ad-f85
    8ad-f85 Well-Known Member
    Jul 25, 2014
    1,780
    212
    Sure does look like oil control but I wonder if leaving them out is fine?
    I'd clean them an put them back if I wasn't deepening the pan in the same area.
    Use a nice clean welding machine.
  4. Cadiac
    Cadiac Active Member
    Nov 27, 2004
    1,829
    3
    Wichita, Kansas
    I cleaned mine with laquer thinner worked real well. Just prop the pan and let a puddle sit for awhile. Then blow out with air
    Carb cleaner will work or something else?? Regular parts cleaner wont disolve it
    8ad-f85 likes this.
  5. peter phillips
    peter phillips Active Member
    Jun 2, 2011
    242
    54
    Mississauga Ontario canada
    Think of it as a dirt trap. Otherwise the dirt gets roiled up by the stops and starts of the car and ends up plugging the oil pump pick up. Motor starves for oil and kaboom. It's some nice cadillac engineering.
    Peter
    PJ McCoy and 8ad-f85 like this.
  6. Caddy123
    Caddy123 Member
    Sep 9, 2016
    49
    Thanks for the answers .
    For sure i make a new one to put in.
    I think also its a dirt trap!
    gr Danny
  7. CanadianC10
    CanadianC10 Active Member
    Sep 9, 2011
    792
    36
    looks like a way for forward oil control under hard breaking
