Intakes , intakes and more intakes
I hear you loud and clear. A big dual-plane with 8 fuel injection ports would be very handy for guys that are ready to ditch the 850 double-pumper carb !!
jwsunup
orange texas
24 model T roadster p/u with 500/ t350 jag irs
making progress on the turbo setup... IMG_20170327_192502957.jpg IMG_20170327_192502957.jpg
Now, THAT is interesting!! WOW!
There certainly is a whole lot of metal fab and welding on that little after school project. :notworthy:
Has it been run yet?
bro. "impressed" d
Nice setup. I hope you aren’t feeding that monster with the fuel pump pictured?
One of the interesting things with the caddy engine is what we have in intake manifolds ... the most common being the edelbrock ..... before that we had modified stock intakes or converted 460 intakes ... then there is bulldog and boogieman and the 1475 intake ...beyond that you have hand made intakes ..... the crazy part is almost all of them are built without any testing leaving it up to the user to make them work or just deal with the problems
I've cut up ford a460 and ford c460 intakes and rewelded the parts to aluminum flanges I made. I set up a set of heads on engine on engine assembly stand. Use 75%helium25% argon gas to get heat at torch without too many amos through welder. I was told after making them it won't work you can't do that. Well It will idle down to 600 rpms and rev to 6500 on 512 mechanical roller cadillac big block. Massive plenum too. 1050 dominator. Push the gas peddle and hold on! No bog just instant go pinned to the seat.
A460 intake fit to Cad500.
Here's a tunnel ram intake with two 830 cfm hollers. It went 10:30et@130 mph quarter mile. 3780 lb car.
