Gm full size 14 bolt rear/94 Cad limo
Cadiac
Wichita, Kansas
Rear from a 94 Fleetwood limo, 14 bolt GM diff housing. Should fit 77 and up Cads/big GM's.
http://www.ebay.com/itm/14-Bolt-9-5-5-l ... 25af9f2738
Description--- Rare coil spring 5 lug GM 14 Bolt 9.5" rear axle. Housing and axle shafts only. NO gears or differential carrier.
This is the narrowest 14 bolt 9.5 that GM made.
33 spline c-clip axles. Semi-floating. 5 x 5" bolt pattern.
Accepts all gears and posi/locker carriers for the GM 14 Bolt 9.5 and there are many options now.
Used brake drums are included.
61.75" from wheel mounting surface to wheel mounting surface. Measures 50.25" inside the brake backing plates at the narrowest part.
Has 11.16 x 2.75" ("truck")brakes.
Pick up only in Eastern PA. This item will NOT be shipped.
Actual item is pictured. Good bearing surfaces on the axle shafts. Housing is straight.
This is massive compared a little 10 Bolt or 12 bolt. Comparable in strength to a Dana 60.
Came from a 1994 LT1 Cadillac Fleetwood Limo.
DevilDeVille
Estonia (next to Russia)
Have one in my ´78 SDV with ´74 500. Put 3.42 gears in it along with Detroit TrueTrac and TA Performace cover withs cap supports. Hoping to find time, to finish my hi-comp 500 to see what this rear is really worth.
