G body headers
Discussion in 'Big Block Cadillacs' started by 5one9, Jun 5, 2019.
  1. 5one9
    316
    99
    Does anyone have part numbers or pictures of BBC headers adapted to a 500 for a G Body? or early Chevelle for that matter. I have two sets, neither of which are satisfying the need. One is a set of G Body long tubes and the passenger side is built to totally interfere with the AC box. The other is a set of Sanderson A Body mid length that interfere with the passenger upper A-arm and driver frame. The Sandersons can be made to work but I wonder if a set of BBC mid length or long tubes would be easier to manipulate onto a set of Cadillac flanges.
    Any suggestions or pictures would be appreciated.
  2. Cadiac
    Cadiac Active Member
    Nov 27, 2004
    1,862
    19
    Wichita, Kansas
    I had someone do mine from bbc chevelle headers. He still hates me!
    Was muchwork he said. Right side most work because of Head staggerd forward of left head. Crossmember and starter are there. Plus my engine is 2.5”” over that way
  3. Caddylackn
    Caddylackn Member
    Sep 7, 2015
    94
    37
  4. richie49
    richie49 Active Member
    Nov 19, 2005
    331
    77
    5one 9
    Ted an earlier owner of this board said that the 460 ford headers are similar tube spacing and the ford has the tubes like a caddy with the # one forward unlike the 454's have.This is something you might look into. Anybody else remember this?
  5. Darius
    4,272
    727
    https://cadillacmagazine.com/forums/threads/500-turbo-build.17440/#post-184149
    In the for sale section you asked about the Sanderson Headers and I don't think they really do hug very well. On my T-Bird I used 460 Van headers
    http://www.summitracing.com/parts/hed-8 ... plications
    They most likely also make 460 headers for your Torino that you can switch the flange on.
    http://www.summitracing.com/search/part ... e/7-5l-460
    Here's where I made the headers for the T-Bird.
    viewtopic.php?f=3&t=12273&hilit=headers+ted+started
    But since you plan to use the turbo everything has to be more custom than this.
    Ted
    Ted in Olympia, Sep 24, 2015 Report
