Deville Went Down to Georgia - Build
Discussion in 'Big Block Cadillacs' started by nosgood, Jul 10, 2017.
  1. Darius
    3,551
    245
    Hello Nick,
    I still love the look of your car. It just has a certain presence, a Je Ne Sais Quoi.
    A project as involved as yours can generate a great number of varied questions. How about ordering up a shop manual for a 1968 Cadillac Coupe DeVille? They are readily available on the Internet for very reasonable costs. Not only are ‘paper’ copies available for less than $23.00, CD-Rom versions can be had for less than $18.00. With a manual answers would be right at your fingertips. Take a look:
    https://www.google.com/search?sourc...95...0j0i131k1j0i10k1j0i22i30k1.0.9wFavJwuqWA
  2. nosgood
    nosgood Member
    Jun 10, 2016
    136
    23
    Dawsonville, GA
    Hi Bro D, thank you! I appreciate the comment. I actually do have a shop manual; it has saved me many times. However, with custom applications such as this, as well as advancements in technology, I like to run things by you experts, just in case anyone has advice that may be better than that of the shop manual’s.
    -Nick
  3. mario
    mario Well-Known Member
    2,829
    64
    Nick:
    When you get your tank boiled out (some radiator shops do it,) have them add in a return nipple. The heater hose can be "tee'd" in to the bottom radiator hose. There are fittings to do that. The modulator was plugged in to the back of the carb and that is the connector from the kick down switch.
    ciao,
    mario
  4. PJ McCoy
    PJ McCoy Active Member
    819
    146
    Ditto:
    Exactly how mine is connected.
  5. PJ McCoy
    819
    146
    Nick
    I Screenshot_20171127-075552.png found this. It might work for both of us. I dont want to tap my block and i dont have room in my Trans Am to cut my lower rad. Hose. Drill a hole in the upper side of the rad. For return?
    What do you think?
  6. nosgood
    nosgood Member
    Jun 10, 2016
    136
    23
    Dawsonville, GA
    Hi guys, thanks for the comments.
    Mario, I called around and there's a shop in the next town over that will be able to do it. Problem solved! It took me a while to find the correct T fitting, but I found an aluminum one on ebay that will work nicely. Should be here in a few days. I think I have an extra port on my carburetor, I'll have to look in the morning. I also found the diagram for the trans kickdown, I just need to go under the dash and locate it.
    PJ, those seem like they'd work just fine! Luckily, I have space for T fitting. Are you sure you don't have space to cut out a section of the hose and just replace it with a T fitting? If not, the only thing I can see being an issue is getting metal shavings in your radiator from drilling the hole. You'd just have to flush it I suppose. I found an all aluminum radiator on radiatorexpress.com that has the bung for a return line already fitted. Maybe I'll splurge and pick one of those up next year.
    -Nick
    PJ McCoy likes this.
  7. mario
    2,829
    64
    Nick, pj:
    I had the radiator shop solder in the return hose fitting when the recored my radiator in my 56gmc. My 49 has the fitting tee in the lower radiator hose. You can't even see the split. I'll see if I can find the link. I understand that the late model vette fuel filter has a fuel return line, saving the fitting expense in the tank.
    ciao,
    mario
    Auto zone has these: KAT'S Heaters Heater Hose Quick Connector, in different sizes. Link won't post, sorry
  8. Darius
    3,551
    245
    Not Autozone but it'll will work well enough: https://www.bing.com/search?q=KAT'S...smsn=1&refig=70185540b76e4672e93cb079d06bd00d
  9. mario
    2,829
    64
  10. PJ McCoy
    819
    146
    Thanks guys. I need heat, my win-chill gets foggy in the cold mornings.
    The lower rad hose tee could work if i can mount it close to the rad. Like almost touching. Great idea. I woundnt have to drill. That will acually save me money too.
    :D
  11. nosgood
    nosgood Member
    Jun 10, 2016
    136
    23
    Dawsonville, GA
    UPDATE: I pulled the top end last night. Took a little less than two hours, including draining all the coolant out of the system. I’m searching for a good machine shop right now, because unfortunately my regular is booked up through the new year. 27BA865E-F84C-4D83-839B-45EBDE99EE1E.jpeg
    Meanwhile, I’m going to call Holley and make sure I can tap this hole right here, so that I can attach a nitrous micro switch to use as my WOT kickdown. I saw this on another Caddy forum, and I thought it was pretty good. The kit is from edelbrock.
    2163E8D1-128D-44E7-ADE3-D5FAE5E9EF7B.jpeg 55771A10-93AE-4E7B-A861-29B3178A00D1.jpeg
    I also got my trans cooler lines all hooked up. I went with one of Dave’s recommendations, and it was perfect. -6 line all the way from the trans to the radiator. At the radiator end I used a 5/16 -20 inverted flare to -6 an fitting.
    D24803BA-A5C1-4E42-869C-45183562EBB5.jpeg 24163932-5DFE-4508-8CF9-9DB318963156.jpeg
    Also, PJ, check this out. It’s like the piece that Mario had links to. I got this one from eBay, and it’s nice. All aluminum and exactly as advertised. 1 1/2” with a 5/8” tee. Works great, and doesn’t take up much room at all.
  12. mario
    2,829
    64
    Great nick, glad it worked out. If you need more space cut a half round notch in each hose where it lines up with the 5/8 tee and you can fit the two hose ends together. If your end cuts are straight, you won't be able to tell that there are two hoses, except for the two clamps.
    cioa,
    mario
  13. PJ McCoy
    819
    146
    Awesome!! Thats great. Looks better than i thought too. I will do that.
    Thanks Mario for the option of cutting the hose. That will help me.
    Ill tru to remember to take some pics Monday. Its really tight in the Trans Am. I have a ?drag link? In my way. Think thats what its called. Im at work so cant get pics.
    Btw Nick. You have a great build. I enjoy keeping up with your project. Thanks for sharing.
  14. nosgood
    nosgood Member
    Jun 10, 2016
    136
    23
    Dawsonville, GA
    thanks PJ I appreciate it!
  15. dave brode
    dave brode Well-Known Member
    14,806
    96
    I'm not bashing, but you asked > Where should I route this lower heater core hose? I believe it went to a cylinder head originally. Can anyone verify that?
    Since both of your hoses go the the inlet side low pressure] tank, you have very little pressure differential, you may not get much flow through the heater core. If you are unhappy with the heater output, you could do what was on earlier cars. They had an outlet below the dist, under the alt. The boss is there, and taps easily to 1/2" or 3/4" NPT. Cast taps nicely. You can buy barbed heater hose fittings at most parts stores.
  16. Andy V
    Andy V Active Member
    Oct 22, 2004
    1,401
    14
    Harrisburg, PA
    what are you planning for engine work, maybe I missed it ?
  17. nosgood
    nosgood Member
    Jun 10, 2016
    136
    23
    Dawsonville, GA
    I have a plug stripped out in my passenger side head, I just need to drill it out. While one head was off, I figured why not remove both of them and switch to ARP head studs.
    -Nick
  18. PJ McCoy
    819
    146
    Mine finally came in.
    Maybe i want have snowballs now after an hour or so worth of driving
  19. PJ McCoy
    819
    146
    Im going to do like Mario suggested. Bring the hoses together by cutting the birdsmouth. It will fit but be very tight.
  20. nosgood
    nosgood Member
    Jun 10, 2016
    136
    23
    Dawsonville, GA
    Hi everybody, it’s been a while! As I’m sure you all know, life frequently steps in the way of building hot rods. I haven’t made as much progress as I’d like, but I have been chugging along slowly but surely. Read on for details:
    As you know, I had to pull the top end off to fix that plug. I swapped gaskets, installed an ARP stud kit, and put it all back together.
    You also may remember my fuel tank dilemma. The local shop quoted me $600 to clean out my old tank, re-line it, and weld in AN fittings to bypass to original outlet & return. A little steep, right? So I stared calling around to custom shops, and Boyd Welding in Florida hooked it up! For $800 I got a fully custom aluminum fuel cell that fits perfectly in the stock location. I’m extremely happy with the final product. Took about a month from the initial quote to having it delivered to my door. Check out those welds!
    ECA128E4-8B27-430E-A762-1574AEC2E354.jpeg 2AF949D2-3BF9-40DA-AD9E-AD39418D5152.jpeg B91D805C-08C3-41D9-A7A1-1BAB7CFF3F64.jpeg 48C6DCCF-90F0-48A7-9184-C5C9011B023C.jpeg E82A2F1C-0C34-4DEB-98D1-A0BABF8A3D3C.jpeg
    I made a few modifications to a Classic Instruments fuel sender, and it fits perfectly.
    Best of all, I get to use my stock filler neck!
    So I went to start the engine for the first time a few weekends ago. It was a big day. I’ve been at this for more than a year, and I am itching to hear this thing rumble. But it wasn’t meant to be; not yet, at least.
    I was getting a very slight back pressure coming out of the top of the carburetor under cranking, resulting in a few pretty gnarly backfires. I adjusted the initial timing to perfection, thinking the issue was there, but my final conclusion was that my pushrods are about .030” too long, thus holding my valves open on the compression stroke. I must have mis-measured when I was assembling the first time around. Rookie mistake, and now I know. I’m ordering a set of adjustable rocker arms, and Paul at MTS is allowing me to return the set I already have. If the new rockers aren’t adjustable enough to get the proper lash, I’ll just order up new pushrods and be done. We shall see!
    El Diablo likes this.
