Come on man!
Discussion in 'Big Block Cadillacs' started by 5one9, Aug 6, 2019.
  1. 5one9
    316
    99
    108mph at 4950lbs ain’t bad at all
  2. 5one9
    316
    99
    What are your heads? Ported? Valve size?
  3. Cadillac Kid 1
    1,142
    237
    Stock heads. Oh wait they are not MTS CNC with 2.18/ 1.85 valves
  4. 5one9
    316
    99
    That certainly helps things along
  5. 5one9
    316
    99
    She finally got fired up and dang she sounds good. The roller cam and full 3” exhaust make for an unbeatable sound. Now to figure out the shifter to actually drive the thing. Worst case is putting the B&M ratchet in. I had planned on the stock column shifter but I’m getting impatient.
    Red98422 likes this.
  6. 5one9
    316
    99
    What is everyone working on this winter? I’m rebuilding a TH400 I had in the shed to handle the 500 with some nitrous that I’ll add for the grudge drags this coming year.
  7. Red98422
    Red98422 Active Member
    Jun 6, 2018
    372
    Right now I’m scrambling to get all my crap together to send out to the machine shop and my self imposed time frame is February...and of course I have to have all of it at once otherwise it’ll be multiple trips.
    5one9 likes this.
  8. richie49
    richie49 Active Member
    Nov 19, 2005
    331
    77
    I dont think I'd like a column shift ,too easy to miss a gear.(from past experience:eek::laugh:) I Myself was getting my corvair ready for inspection so I could drive it. Had to get the front turn and running lights to work and got those fixed and was working on the wiper switch ,wipers work but the switch is not so good. Since I had to have the key on I didnt notice the electric fuel
    was on, and the dang carb flooded,filled the intake ,several cylinders with gas, pulled plugs turned the engine over got all the gas out. Changed oil and filter and pulled carb,darn little clip on the float needle caused the trouble.The carb is fixed(hopefully) and ready to go back on.But that looks to be after the first..
    Its the start of a New Year so I hope everyone get all those little picky things fixed and get to enjoy their cars.
    Red98422 and 5one9 like this.
  9. 5one9
    316
    99
    I ended up putting the B&M in the car.
  10. Darius
    4,271
    726
    Me, I head into surgery Monday morning. So much for getting everything on the car done before hand. Oh well, I tried.
    I did manage to spec, and then buy, some components set to mount the cradle of the Ford 8.8 Independent rear into the S10 frame. The materials are probably a bit overkill in terms of material thickness but when dealing with the torque of a twin turboed Caddy 500 it seemed prudent to go Big. Also managed with the help of a friend (and his truck) to get both of my 100 pound propane tanks to the fill station. Their heat will allow me to at least be in the garage following surgery (Lord willing) to practice my TIG welding skills since the doctors says I won't be able to even get on a creeper for six months. The good news? By then my welding might be pretty decent.
    Happy New Year to all you Gents!!
    bro. "soon to be splayed open" d
    (Just for your viewing pleasure I've asked the doctor for pictures during the procedure - You'll be on your own for treats!)
  11. 5one9
    316
    99
    Best wishes for your recovery. You should be a TIG pro by summer.
  12. gordon
    gordon New Member
    Jan 12, 2017
    22
    Not to High Jack the thread by 50ne9 but Darius is that 8.8 IRS unit out of a T-bird?
  13. Darius
    4,271
    726
    Howdy Gordon,
    Yes, it is the 8.8 IRS out a T-bird. Intentionally went with the 3:08 gear set and supplemented them with Detroit TrueTrac version of the Torsen limited slip.
    (https://www.jegs.com/i/Detroit-True...0&cadevice=c&gclid=CMjmq9C3jNUCFUFsfgodD-MHsg)
    Yes Gentlemen, I survived the surgery. Rough journey but this is my third day home. Still waiting for my mind to catch up.
  14. 5one9
    316
    99
    We’re glad everything went well for you. You’ll be TIGing in no time. I’m assuming you’ve watched all of the YouTube videos showing how ridiculously easy it is?
  15. Darius
    4,271
    726
    Monzallac 425, Red98422 and 5one9 like this.
  16. 48Austin
    Oct 14, 2017
    485
    263
    D. Kids look simple:rolleyes:. There you go:(.
  17. Darius
    4,271
    726
    Point made, well made! :laugh:
