Chevrolet thermostat conversion for a big-block cadillac
bapajimbo
AR
56 Studebaker Flight Hawk hardtop, 14 Smart car co
looking for info/pix on the chevrolet thermostat swap on a big block cadillac
Don't understand the question. Thermostat it self or housing?
robocop
Miami, Florida
Do not use a Chevrolet thermostat in your Cadillac. You will have inefficient cooling. The Cad thermostat has a plunger closes a passage to then route coolant for most efficient cooling after a quick warmup.
bapajimbo
AR
using a chevy hi-volume thermostat keeps the big Caddy running cooler than the stocker. you have to do to make it work is put a 1" softlug into the by-pass hole (after driiling a 1/8" hole to relieve any trapped air in it). worked great for me! There is no need for a by-pass on a hot rod!
Still didn't understand question? Maybe I'm just STUPID! Been twistin wrenches for 50 PLUS YEARS! NEVER HEARD THESE ANSWERS!!
robocop
Miami, Florida
I tried the bypass plug and a regular thermostat in my 500 and saw the engine temp get very high before enough hot water got to the thermostat to open it.
I went back to a Cadillac thermostat. Does the John Deere thermostat have the plunger? I want a 160 thermostat and the coldest Cadillac one I could find is a 180.
