Big big block Caddy
Discussion in 'Big Block Cadillacs' started by Cad Man, Nov 8, 2018.
  1. Cad Man
    Cad Man Member
    Oct 11, 2018
    99
    26
    Now that we actually have semi affordable forged 4340 cranksahfts to pick from possible Big Caddy cubes some may not know are possible..
    With no fill we have 4.360 bore. Or 4.420 bore.. Possibly 4.440 bore with no or only partial fill....Or. Full fill
    4.500
    4.360 x 4.600 = 549
    4.42 x 4.600 = 565
    4.440 x 4.600 = 570
    4.500 x 4.600 = 585
    4.360 x 4.750 = 567
    4.420 x 4.750 = 583
    4.440 x 4.750 = 588
    4.500 x 4.750 = 604 cu in Mad Cadder Caddy..
    These are now off the shelf items..
    The big crank pretty much drops right into the block . Cadco offers a optional custom crankshaft . it is possible there may be even larger strokes in the future
    PJ McCoy likes this.
  2. bugzaper
    bugzaper Well-Known Member
    Nov 23, 2005
    1,590
    50
    :thumbup:....crazy big numbers!
    (now...what kind of prices are we talking about)
  3. Cad Man
    Cad Man Member
    Oct 11, 2018
    99
    26
    Thats hard for me to answer because I've known him for so long I get things discounted.
    As for a retail price...Let's put it this way
    it's less than in 1992 when I went to Moldex cranks which was about 1 mile from my old house they wanted $3400 and had no idea what kind of stroke could fit.. not to mention the improvements in crank design since then
    That's the 4.750 stroke the 4.600 is a few hundred less..
    And before you gasp think about how it's getting hard to find a 500 crank. When you do it is getting more and more pricey and then you have no idea what kind of stupid shit the previous owner did to and with it.. then getting it ground and prepped.. or offset ground which has ended in disaster more often then not with incompetent machine hacks.. and then you still have a 50 year old plus piece. I was drooling at the chance when he gave me the price..
    Btw
    It has 2.200 rod journals and I'll go with 7.1 rods if I get it.. that makes for a short light piston too.. 1.330 comp height I believe
  4. Cad Man
    Cad Man Member
    Oct 11, 2018
    99
    26
    And one more thing maybe most importantly of all a crankshaft like this will be practically indestructible it will be the last crank you'll ever need to buy in a 500 even if it gets damaged it can be repaired in the stronger more rigid crankshaft will also add to the strength of the block
  5. Red98422
    Red98422 Active Member
    Jun 6, 2018
    125
    33
    It’s posts like this that tend to give me bad ideas...:sneaky::devil:
    That being said I can personally attest to the fact that cad cranks are really hard to find, at least in my area. I was fortunate enough that Shakedog was liquidating and had one that he sold me (it was still a 6hr one way drive)
  6. Cadillac Kid 1
    Cadillac Kid 1 Active Member
    897
    92
    yes,
    I just bought a couple of motors for the cranks. Just what everyone needs, more Cadillac motors. Right Marty?
  7. 48Austin
    48Austin Active Member
    Oct 14, 2017
    181
    85
    berwyn
    Still haven't given an answer on or about price.:cautious: Where are the forgings or billits made:cautious:?
  8. 48Austin
    Oct 14, 2017
    181
    85
    berwyn
    What about alloy rods?
  9. Cad Man
    Cad Man Member
    Oct 11, 2018
    99
    26
    I came as close to it as I honestly can...
    I gave a general idea of cost because I dont know how much he sells to others for.. I get special pricing because I've been a customer since 1990.. and have bought lots of stuff
    The cranks use chebby rods so you can use whatever rod you like.. I going with 7.1 rods but he carrys 3 different lengths.
    pistons are per order because everyone wants different compression bore size and different heads ..
    Obviously he went thru alot of bullsheet no one else has done or is gonna do to get the cranks made and on his shelf .. So the source is perpritory. But its USA
    It's not a zillion part order so no chinese manufacturer would touch it
  10. 48Austin
    Oct 14, 2017
    181
    85
    berwyn
    Will the longer alloy rods clear the block, or will the lower bores need to be clearance ground? You know that alloy rods are physically bigger.
  11. Cad Man
    Cad Man Member
    Oct 11, 2018
    99
    26
    Yes they clear with no machine work ..
    How about this. 30 years ago Larry K told me about a guy that siamese sleeved a Caddy block to take advantage of the 5" bore spacing and made a 590 inch Caddy.
    Just found out who that guy was. Courtney Hines. And he may just do another ..
    4.625 x 4.750 = 638.4 cu in of Cadillac
    Now that's a big Caddy
    Oh I almost forgot..
    There are 12 forged 4.600 cranks..he only has 1 left right now..
    There are 5 forged 4.750 cranks .. he has 4 of them and I have 1. Hehehehehehehehe
Users found this page by searching for:
  1. cadillac forums 472 500 cu in
