900 HP
Discussion in 'Big Block Cadillacs' started by Cadiac, Oct 9, 2018.
  1. Cadiac
    Cadiac Active Member
    Nov 27, 2004
    1,862
    19
    Wichita, Kansas
    D8BB79DE-1303-4A6F-AE86-AFE78E000E69.jpeg 4A136D1C-1D63-429B-9DB4-1F25F7700417.jpeg 3AAEC78D-D00C-49EA-A0B4-C4396A584A83.jpeg O Post on facebook from Cad Co
    It’s been a while since we’ve posted anything so we have some catching up to do.
    900HP Cadillac ?
    Yes, we made over 900HP recently on gasoline with NO power adders.
    In the ‘70’s we made over 600HP and over 800Hp in the ‘80’s, so this was a milestone for us.
    I guess we shoot for 1,000 next!
  2. Darius
    4,273
    727
    Now, that is right impressive!
    As you may know I am a 'forced induction' type of guy but numbers like you just posted can be reached naturally aspirated, if not easily. Hell, you just did it!!
    Tell us the combination used to reach that lofty goal. The compression ratio, camshaft specs and RPM had to be aiming mighty high!!
    Roy Heisenberg likes this.
  3. Cadiac
    Nov 27, 2004
    1,862
    19
    Wichita, Kansas
    Peak HP was reached at 6550
    Im gonna talkto Courtney and ask all specifics. Got rather excited myself I wanna know how they are safely spinning that high!? Cadiac goes across stripe about 6100. With smaer tires it was at about 6300 whenTerry found out he cringed. I bought taller slicks haha
  4. Cadiac
    Nov 27, 2004
    1,862
    19
    Wichita, Kansas
    added there pics
  5. bugzaper
    bugzaper Well-Known Member
    Nov 23, 2005
    1,621
    77
    "Good lord" those are huge numbers!!!
  6. nosgood
    nosgood Active Member
    Jun 10, 2016
    223
    72
    Dawsonville, GA
    Yeah I'd like to see the specs on that thing as well. Great jobs guys!
  7. Red98422
    Red98422 Active Member
    Jun 6, 2018
    372
    Holy crap....900hp NA is a pretty big deal even nowadays. So congratulations on the numbers!
    Did anyone else notice the intake is an old “bulldog”? Also looking at those headers...I bet they would be perfect for a boat!
  8. Darius
    4,273
    727
    Pictures? I don't see any pictures on my view of the forum.
    Peak at 6550 is less than I had expected. My bet was that those numbers came north of 7,000! That sucker (pun intended) must be breathing deep and well!!
  9. El Diablo
    El Diablo Active Member
    Apr 25, 2013
    411
    126
    Yuma, AZ
    1959 Cadillac Sedan deVille
    I see it has a big Dominator. I wonder how far apart a 950 cfm 4150 would put it?
  10. Cadiac
    Nov 27, 2004
    1,862
    19
    Wichita, Kansas
    Called Courtney. Ported boogieman heads, 1150 carb said might use bigger? Big solid roller cam about .800 lift 14:1 comp, flat tops with relief cuts. Stroker billet crank/3K, About 582 cid. Don’t recall stroke but rod journals are bb chev
    Said he hadn’t priced it but probably around $20,000 if you have him build one
    Darius you can’t see three pics I added to first post??
  11. Cadiac
    Nov 27, 2004
    1,862
    19
    Wichita, Kansas
    He said hes been spinning Cads 6500 since the 70’s even stockbshort blocks. Yikes!!!
  12. Darius
    4,273
    727
    NOW, I can see those pictures but somehow they did not show up when I first opened the thread. Strange.
    First of all, GREAT Pictures!! They help tell the story so much better, and they are appreciated.
    Those compression and lift numbers are about what I expected. I had not understood that the beast was stroked (pardon the expression:rolleyes:). Still, even with the added cubes those HP numbers are impressive especially given the RPM at which they are achieved. Courtney may have been spinning those large crank throws that hard since the 70's but I've long preferred that level of abuse limited to short stoke engines with 2.6 inch, 2.8 inch or 2.94 inches of throw. Staying in that range lowers my "pucker point."
    Thanks again for the info.
  13. El Diablo
    Apr 25, 2013
    411
    126
    Yuma, AZ
    Do I sense a return to the Engine Masters competition in the near future?
  14. Cad Man
    Cad Man Active Member
    Oct 11, 2018
    307
    281
    They ran out of fun time. He was still testing with a Bulldog intake.. 1475 and 1250 carb will certainly make more power.
    This is not a girdled block.
    It has. Main studs cap straps and halo.
    STOCK cam journal dia.. .800 lift 280/290 @.05
    Mildly ported Boogieman heads..
    (Same porting as mine) hehehe
    582... 4.750 stroke... 4.42 bore...
    Btw the peak came at 6500 but some of the pulls have been over 7000 rpm
    With that giant arm. Pretty darn impressive
  15. 48Austin
    Oct 14, 2017
    485
    263
    PUT A BLOWER ON IT WITH E-85.
    Cadiac likes this.
  16. jwsunup
    jwsunup New Member
    Jan 3, 2012
    17
    orange texas
    24 model T roadster p/u with 500/ t350 jag irs
    I'm impressed that the old style Bulldog manifold supported those numbers! I knew they were the best production intakes available but thought they would run out before those numbers...More cfm will pick it up more...I'm running two 600's on the street and I'm nowhere near this compression, lift or stroke. My hats off to you!
    Roy Heisenberg and PJ McCoy like this.
  17. Darius
    4,273
    727
    What is your combination? In the same way, do you like the overall drivability of your twin carb set up for the street? I'm curious because it is street driven and not a track only car.
    Curious d
  18. PJ McCoy
    PJ McCoy Well-Known Member
    1,170
    341
    I was sharing my thoughts with Julius and he mentioned some amazing numbers coming from your shop. So glad to hear the new developments. Keep us posted.
  19. PJ McCoy
    1,170
    341
    OK "Cad Man" what he using for oiling as you know that's another big issue for these cads.
  20. PJ McCoy
    1,170
    341
    D whatso going on? Pucker point? Forces induction? Sounds like prison talk to me.
    Ouch!!
