- gears are 4.57 with a 30.5 tall tire. Hits about 6100rpm going through the trap.
Last time I had the truck to a track it was 4.11 with a 28" tire
Get better traction.. Dont leave so high on the converter.. don't completely hammer it..
I doubt its overgeared .. whats your rpm thru the traps ??
make it the best you can before hurting your possible et...
of course I cant recall your tire height ?? 31's ?? if anything go to a taller tire
BTW..
taller tire puts more rubber on the ground
Slicks ??
I bet your actual gear is close to the same.. 32.5 or 33 would be or better..
6100.. I don't know with your heads ?? I think your cam is good past that.. either way its not to nosing over .. Most would tell you to run out of gear before the line..
As you said ..It usually dosent work better for us.. I think you need to get a good pass in and then decide.. no point in swapping gears till then IMO
Agreed..I don't think 2800 is high for a 4000 stall converter
and I don't want to make changes to the performance capability of the driveline to bandaid where the suspension falls short - id rather make the suspension work a little better
