500 engine in S10
Discussion in 'Big Block Cadillacs' started by John Milner, Jan 13, 2020 at 10:20 AM.
  1. John Milner
    John Milner New Member
    Aug 15, 2007
    16
    0
    I have a nice rebuilt 500 engine that is ready to go in something. I'm wanting to put it in about a '90 S10 truck. Has anyone ever made this conversion before?
    Thanks
  2. Monzallac 425
    Monzallac 425 Active Member
    Jul 16, 2008
    846
    50
    Salinas, Puerto Rico
    I think it was done once, but I don't remember the details, maybe one of the op's will though.
    I don't think it would be too big of a deal, since you can pull the front clip off. Hey, I fit a 425 in a GM HBody only the second out of 3 to try it. (#1 was in a Vega , # 2 gave up!)
    Anything is possible if you try.:thumbup:
    Doug in P.R.:cool:
  3. Darius
    4,165
    680
    "Kind of" is my answer to whether or not anyone else had mounted a big block Cadillac (500) into a first generation S10 pickup frame.
    My Cadillac 500 build uses a 1985 S10 frame. It was a standard cab, long bed, 4 WD unit. Does the engine fit? Yes, easily is my answer. But my "kinda of" reply is because that frame is no longer under a pickup body but a very small 1950 Studebaker Champion 4DR sedan. What would you like to know?
    SHAKEDOG likes this.
  4. John Milner
    Aug 15, 2007
    16
    0
    It sounds like it can be made to fit in the frame them. I have an eldorado pan on my engine, which I feel certain is necessary. Some of my other questions would be what did you use for your motor mounts? Did you use the 500 oil pump/filter housing? Also did you use manifolds or headers? Thanks for the replies.
  5. 5one9
    212
    70
    I didn’t exactly install in an S10 frame but I’m highly confident that it can be done. Worst case you are using a remote filter and building headers. I built my own mounts from 1/4” steel. You can somewhat see them in the picture.
  6. Darius
    4,165
    680
    The pan used in my project is also a Caddy Eldo unit and that fits just behind the front cross brace. One thing to be aware of is the differences between the two wheel drive and four wheel drive frames. The stock 4X4 trucks use torsion bar suspension and that difference alone WOULD APPEAR to make it easier to have clearance for stock Cadillac exhaust manifolds. The 4X4 has taller shock towers and heavier arms (I think). Not idea if the front cross brace is the same or not.
    No problem fitting the 500 oil pump/ filter housing either. If my old memory serves, it is the later style oil pump which nicely points the filter toward the crack and out of the way.
    The engine mounts are home made and pictured here.
    Hope this helps.
  7. Darius
    4,165
    680
    Here are a few more pictures.
    Don't get me started as there are well over a thousand images of the various stages of this project - and I am willing to challenge any proud grand parent against their collection of "first grandchild" photos as for sheer numbers.
    5one9 likes this.
  8. Caddylackn
    Caddylackn Member
    Sep 7, 2015
    69
    25
    The steering shaft, exhaust manifolds, overall width, and the oil filter location are the biggest hurdles for transplanting a 500 into anything. There is also the required radiator size and necessary clearance to the radiator. These challenges can be overcome with ingenuity and fabbing. There is lots of aftermarket support for S10 with V8 swaps.
    There are also the Eldo drivetrain rear engine swaps that can be done to the S10. That would also be fun, there are a few of these out there.
  9. PJ McCoy
    PJ McCoy Well-Known Member
    1,140
    334
    I did the same thing to fit my caddy engine into a 81 trans am.
  10. PJ McCoy
    1,140
    334
    I've seen a Chevy 454 in a rodeo. If the 454 can fit a Isuzu Rodeo then a caddy will fit a S10. The rodeo radiator support was completely cut out. The big Chevy radiator was bolted to the outside and the grill was fitted over it. He used an air Grainger on the chrome plated plastic grill to make that fit. Looking at the truck you would never know. Sawzall is your friend. A friend with welding skills. Priceless.
  11. Darius
    4,165
    680
    Adding corrections to my post #6 above in this thread.
    I wrongly indicated that it would probably be easier to have clearance for the engine in a 4 wheel drive vehicle, as opposed to a two wheel drive one. Actually, due to the height of the shock towers on the 4X4 units there is less room. The tall supports for the front shocks intrudes on the space when the exhaust manifolds are. It is tight, but can be made to fit. A 2 wheel drive vehicle would have more clearance space in that area due to the difference in front shock placement and how and where the A-arms are mounted.
    As a note: I did away with the stock torsion bar suspension on the 4X4 frame and instead went with front coil overs as shown in the pictures.
    Trying to be accurate - even as the years pile on.
