1977 Fuel Injection help
Bruce Roe
The cost to fix the enrichment circuit in the ECU, is less than
the postage. Bruce Roe
G
G-230157
Recently acquired 1977 Eldorado with factory fuel injection, and trying to get it to start.
Car cranks, I get spark, and in-tank fuel pump is running with ignition in RUN position. But the inline fuel pump doesn't run, and I get no fuel to injector rail.
Are inline and in-tank fuel pumps both controlled by the ECU? Is spark/distributor controlled by ECU?
Just trying to get some ideas, i'm suspecting a bad ECU/fuel pump relay, but the car is parked in the grass, and have yet to get under the car to test the fuel pump by supplying 12v to it directly.
I have the same issue with my inline electric fuel pump you will have to connect it directly to the battery that's what I did to mine to fix it
Boltonius
1978 Cadillac DeVille; 1965 Bus with Cad 500
Bruce has repaired the EFI computer in my '78, and it worked a whole lot better after that-especially since my computer is meant for the 350B Olds engine version of this system!!
Regarding the pics of side panel rust.. oof! That's pretty advanced cancer. Time to buy a MIG welder and learn to shape sheet metal.. But in the end you'll have a heckuva disco cruiser!
Ruben pasillas
1977 Cadillac eldorado
I was having the same problem so all I did was bypass it and hook it up directly to the battery and it works fine
