Recently acquired 1977 Eldorado with factory fuel injection, and trying to get it to start.
Car cranks, I get spark, and in-tank fuel pump is running with ignition in RUN position. But the inline fuel pump doesn't run, and I get no fuel to injector rail.
Are inline and in-tank fuel pumps both controlled by the ECU? Is spark/distributor controlled by ECU?
Just trying to get some ideas, i'm suspecting a bad ECU/fuel pump relay, but the car is parked in the grass, and have yet to get under the car to test the fuel pump by supplying 12v to it directly.
